2
Discussion topic: Fibre broadband
This message was authored by hetheron This message was authored by: hetheron
Fibre broadband
Just had full fibre installed
Phone now plugged in to uk phone socket on hub but can I use my other existing phone by using a splitter adapter at the hub phone socket so I can have two working phones ?
This message was authored by TimmyBGood This message was authored by: TimmyBGood Answer
Re: Fibre broadband
@hetheron
Yes, a simple wiring splitter into the socket on the Hub should work (although whether the Hub supplies enough current to permit two handsets without their own power supplies to function is unknown).
A neater solution is to use that socket to host the base station for a set of DECT handsets.
Re: Fibre broadband
@hetheron
Re: Fibre broadband
@TimmyBGood  Use a splitter in the back of the hub and it does work with 2 phones connected.
