Discussion topic: Fibre broaband issues York
This message was authored by: KL227
I have recently moved to sky fibre broadband and have had intermittent internet outages since. This morning it has been down for two hours. The hub shows orange lights on internet and voice but service checker says all is ok and no local area issues.  Any advice appreciated.
Re: Fibre broaband issues York
@KL227 when did you run the service checker? If it was soon after you lostvconnection it may not have picked up,the loss as thstvtakes up to an hour. If it has thdn it can take you through a few steps before offering t o book an engineer. Alternatively call Sky when their lines open at 8am.
Avatar for KL227
Thanks. Tried a few times with same result. Will call sky when it opens as you suggest
