Discussion topic: Fibre box install
This message was authored by: Woody376
Message posted on 17 Jul 2025 10:25 AM
Fibre box install
I'm due to getvsky Fibre to the home next Tiesday and was told a sky/openreach engineer would be round to fit a box on the outside of my home. There was a van outside yesterday but they were at next doors house. I was wondering how I find out if they have 1 gone to the wrong property or 2 when mine is likely to be fitted? Thanks in advance
Find out more
Message posted on 17 Jul 2025 10:26 AM
Re: Fibre box install
Unfortunately no one can tell you if the engineer was for you or not, what does your order tracking show?
Message posted on 17 Jul 2025 10:44 AM
It just says the conversion kit has been delivered, which was just an ethernet cable.
And the next 2 steps sky full Fibre activation says activation due and sky full Fibre install says in progress
