Discussion topic: Fibre Details
This message was authored by: ugroenewald
Fibre Details
Where can I find my connection type, username and password and VLAN ID?
Re: Fibre Details
@ugroenewald
Are you in the UK or Ireland?
Are you on full fibre fttp, part fiber fttc or copper adsl
Avatar for ugroenewald
Re: Fibre Details
I am in the UK and have FTTP (i.e. Fibre to the Property)
Re: Fibre Details
@ugroenewald Your connection is FTTP to your property,  and the "username and password and VLAN ID" are more than likely irrelevant. Is there something specific that you are trying to do.
Re: Fibre Details
@ugroenewald Sky do not use a unique log in details. Any router connected to the line can authenticate the connection by using DHCPv4 Option 61 with a standard string anything@skydsl|anything assuming the router supports thst. If it doesnt most but not all lines will connect using DHCPv6 PD.
