Discussion topic: Fibre Cable size
This message was authored by: Boogie2
Message posted on 04 Mar 2026 05:49 PM
Fibre Cable size
What is the diameter of new Sky Broadband Fibre cable into house?
Message posted on 04 Mar 2026 06:13 PM
Re: Fibre Cable size
@Boogie2 Varying sizes so all depends on the one you are talking about! External with all the protection is about 6mm.
Find out more
Message posted on 04 Mar 2026 06:52 PM
@Boogie2 the pigtail cable Openreach use is quite thin around 2 -3mm in diameter st a guess. But note the.installation engineer will want to drill the access hole and fit a plastic firment that protects the cable and weather proofs the hole.
