Discussion topic: Fibre Broadband
Message posted on 04 Aug 2026 05:12 PM
Fibre Broadband
Ever since I have had full Sky Fibre I am unable to get WiFi in my kitchen . Is there a solution to this ?
Message posted on 04 Aug 2026 06:06 PM
Re: Fibre Broadband
@Highpeakhonda if your hub has been moved which commonly happens when full fibre is installed that will cause the WiFi signal to change. In a few cases where customers have Skype Q and the switch to fibre came with a new white Sky hub the Q boxesxstop acting as WiFi extenders which also changes the WiFi signal.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
