Discussion topic: Fibre Broadband issue
Message posted on 22 Sep 2026 09:45 PM
Running very lagging 1/100th of speed it should be at.
Message posted on 23 Sep 2026 06:16 AM
Re: Fibre Broadband issue
@DL43 how are you measuring speeds? If ot is on a device connected to your hub by WiFi you are probably simply measuring the speed of the WiFi connection in your home. Sky test the broadband speed to your hub every day and you can see thecresults in the Service Checker in the My Sky app orcwebsite.
However poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the answer is additional wifi sources.
