Discussion topic: Fibre 100
Message posted on 18 Dec 2025 05:57 PM
Fibre 100
Since getting this in my son can't get no connection or very poor connection we never had a problem since router been moved!
Message posted on 18 Dec 2025 07:27 PM
Re: Fibre 100
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 18 Dec 2025 07:34 PM
Re: Fibre 100
@Gill118 You should look to see if it is possible to move the sky hub back to where it was previous. Longer Ethernet cable may be all that is needed to do so!
