Discussion topic: Fauty connection
This message was authored by: Chorrykid
Fauty connection
Wi-fi fails to connect to devises and when you get it connected it keeps disconnecting . The house is sandstone and seems to have a problem with the signal. Alexa devices dont work struggle to connect a printer. Never had these problems wit BT
Re: Fauty connection
@Chorrykid any building with solid stone walls is going to present serious issues with WiFi. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
