Discussion topic: Faulty broadband
This message was authored by: ElleandMarty
Faulty broadband
Hi our broadband isn't working despite all the checks
Re: Faulty broadband
@ElleandMarty
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
