Discussion topic: Faulty broadband
Message posted on 07 Dec 2025 05:04 PM
Faulty broadband
Message posted on 07 Dec 2025 05:20 PM
Re: Faulty broadband
@Stevenmacgregor
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
