Discussion topic: Faulty Sky Hub
This message was authored by: Cocheese
Message posted on 09 Jul 2026 06:59 PM
Faulty Sky Hub
My sky hub keeps dropping the interent connection it reconnects for about 20 minutes then drops for another 10 minutes and this cycle continues, this is happening to me every two weeks, sky diagnostic says my connection is fine but there no white light and no connection, requested a replacement hub from sky well over a month ago, was told I'd get a call back which never happened, this problem is driving me insane, I have tried everything, reset, power cycle, reduce temperature, its not near anything that can interfere so it must be a faulty Hub and customer services have proven to be completely useless.
Find out more
Message posted on 09 Jul 2026 07:29 PM
Re: Faulty Sky Hub
Try running this line test to see if it finds any faults:
If nothing si found you will need to do as you did before and call them again about this.
