Discussion topic: FY8 OUTAGE
This message was authored by: pam71253
FY8 OUTAGE
Finally got Internet back after 12 days. Now lost it again.
Re: FY8 OUTAGE
@pam71253
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
If you’re still having problems you may need to contact Sky again to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Avatar for pam71253
Re: FY8 OUTAGE
Thanks for your help. There's been an Internet outage here for 12 days as a car destroyed the green box .
Finally this afternoon BT Openreach fixed it and  we had Internet.  Lasted  less than an hour and now no Internet again. 🙄
Not sure what's happening.
Re: FY8 OUTAGE
Do you know if Openreach at still on the site of the issue ?
Avatar for pam71253
Re: FY8 OUTAGE
They were there earlier. Now I hope they're back tomorrow. 🙄
Avatar for pam71253
Re: FY8 OUTAGE
Finally we have Internet.  Sky box working but mini box won't work even though
it's been reset and rebooted and all connections cut and plugged in again.
I'm really stumped.
