Discussion topic: FTTP query for my postcode
This message was authored by: iAshton
My street  in LS19 has recently been cabled by Quickline. Does this mean I'll only get FTTP by moving over to them? They've started mail dropping their initial offer which is less than half my Sky cost.
I'm not sure whether Openreach will do FTTP alongside Quickline in which case I could wait or whether Openreach have 'passed' and will let Quickline have the FTTP business.
Or whether SKY will offer their service over the Quickline infrastructure ( like they do with FTTC and Openreach).
Ours is a semi-rural address. Virgin didn't bother with us so our only option so far has been over the Openreach network.
SKY Superfast Fibre
Re: FTTP query for my postcode
@iAshton
Sky doesn't offer service over anything but Openreach infrastructure at present: there's a deal with CityFibre becoming available later this year.
Avatar for iAshton
Level 2 icon
Quickline are now taking advantage of a government grant and installing FTTP to all 18 properties at our address. Individual houses can then chose to upgrade their broadband or stay with their existing supplier - a mixture of Sky, BT, TalkTalk.
So does everyone have to switch ISP to Quickline to get FTTP or will the new connection be available to the other providers?
SKY Superfast Fibre
@iAshton yes using the new connection will almost certainly require a change in ISP. It isnt a trivial matter for an ISP like Sky to offer services via an altnet like Quickline and the small size of many of these networks makes it commercially not attractive =even if the altnet offers a wholesale product which most don't.
There were several dozen of these altnets but the number is dropping as they merge or go out of business.
This message was authored by: Floydianslip
@iAshton
You can do a quick check to see if OR FTTP is available.
https://www.openreach.com/fibre-checker
Indirect Government investment funding, I suspect, rather than a 'grant'
https://www.ispreview.co.uk/index.php/2024/08/quickline-secure-250m-funding-to-boost-uk-fttp-broadba...
At the end of the day altnets exist to make money for investors and shareholders.
@iAshton Quicline will be haapy to take whoever they can get to sign up to them, just be sure if you do that you do not have long to go with your existing contract if so your cost's off switching are/will be covered to the full extent and that OTS is fully functional with the Altnet!
Avatar for iAshton
Level 2 icon
So once I have a fibre connected to the property it will be Quickline sending bits over it. Openreach's fibre offering will stop at our nearest cabinet for the foreseeable future.
Are any of these "altnets" required to offer hosting to SKY, TalkTalk, BT et al. Over this connection either now or after a designated period.
SKY Superfast Fibre
@iAshton Would say no, deals are done at a level way above and beyond. Sky are OR and CF only at present, with CF limited by there area's and OR UK wide!
No.
Given the very small geographical footprint of most altnets, it's simply not worthwhile for big Openreach ISPs to negotiate the complex technical and financial arrangements necessary for a carriage deal even if the owners were amenable: CityFibre is a notable exception as they can potentially service several million addresses.
Avatar for iAshton
Level 2 icon
I'm  out of contract so paying through the nose to Sky at the moment so I can switch if I want to. Is there an issue with any Off The Shelf software you've come across?
SKY Superfast Fibre
@iAshton The ISP online Forum is where you need to go and check it all out that is where you will find out any pro's or con's etc!
