8
This discussion topic has been answered Discussion topic: FTTP broadband speed check
This message was authored by: PACman63
Is it possible to run a speed test on the FTTP broadband that gives the specific ping rate and upload and download Mbps, rather than being told that it is 'good'?
I can then compare it to independent speed tests.
I don't want to pay for 900Mbps when I am not getting it.
This message was authored by: Highlinder Answer
Re: FTTP broadband speed check
@PACman63I run 3 independent speed tests on my own connection here running them on Ethernet rather than Wi-Fi to give me a more true picture of the speed that I am getting.
This message was authored by: LozDudek
Currently getting 0.6mbps download speed. Signal terrible for weeks and now two at home who cannot work! Yet the network says no issues
@LozDudek if that is measured on a device connected by ethernet you should report it to Sky pronto however if on a device connected by wifi its probable you are measuring the wifi speeds in your home which is a somewhat different issue.
What can be cause of dropped wifi connection then? All our devices are wirelessly connected, so this is the key speed.
@LozDudek if you post your hub's stats we should be able to tell you more but slow wifi is a very common issue in many homes due to the layout, type of construction and level of interference. For example metal blocks wifi signals so having a radiator between where the hub is and the device means it has to rely on rdflected signals or having solid internal walls will greatly reduce signal strength.
See Find your Sky Broadband router statistics
@LozDudek
WiFi is inherently a dynamic environment, susceptible to changes both within the subscription address and those buildings neighbouring it (radio waves not being noted for their ability to recognise property boundaries)
This message was authored by: JPR007
If you want to measure the actual WiFi transmission speed in real time between the router and a wireless device, download an app called "wifi sweetspots". If you run this while moving around in your property it will show the live connection speed between the device and the router. This is not a measure of your broadband connection, it is a display of the WiFi connection between the device in it's local enviroment with it's access point it's connected too.
It might surprise you at just how unstable it is, and this is what WiFi is like, it is determined by physics. No ISP can control it. This is what we mean when we say WiFi is inherently unstable, and is why you get things like high latency, ping, jitter etc.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
This message was authored by: Madhatter
If your DIY competent, you could run Ethernet cables to where your WFH and use wired. If you run as I have outside of the house no major upheaval involved, you can also put a switch at the end to connect more devices.
You could also look at the MESH setup of the ASUS routers for better WiFi
