Discussion topic: FTTP Questions
This message was authored by TrebleTA This message was authored by: TrebleTA
FTTP Questions
So I've just got my FTTP,
first question is the phone, voip.
The sky hub is too far away.
If i get this item. Will I be able to use it to resolve my issue
https://shop.bt.com/products/bt-digital-voice-adapter-100121-bt1-G4Z7.html?utm_source=google&utm_med...
Sky FTTP, SR203 hub self bridged to Asus AX82U. Sky Q UHD to Samsung QE55S95BAYXXU , Sky Q Mini.
Re: FTTP Questions
@TrebleTA
No, that's specific to BT Broadband FTTP, a BT Smart Hub 2 and BT Digital Voice handsets.
This message was authored by Mr+Slant This message was authored by: Mr+Slant
Re: FTTP Questions
Just buy a normal telephone extension cable.
Re: FTTP Questions
@TrebleTA
You can move the Hub further from the ONT with any Cat5e or better ethernet cable.
It's also possible to connect any DECT base station to the 'phone' port on the Sky Broadband Hub and use matching DECT phones.
TrebleTA
Re: FTTP Questions
So is there a version out there that would work with any router?
Re: FTTP Questions
@TrebleTA
Not that I'm aware of: the BT system is proprietary to their Digital Voice product suite.
Re: FTTP Questions
The phone port on the router is simply an ATA interface so any DECT base unit or phone will work.
TrebleTA
Re: FTTP Questions
So there is nothing that will connect in to the phone port and then have a receiver like above?
Re: FTTP Questions
I don't understand what you're asking?
You can connect anything you want into the phone port - ie a phone/DECT unit/whatever. Its exactly the same as the master socket/telephone extension sockets you had before. No difference.
Re: FTTP Questions
Apart from a BT Digital Voice handset or an actual VOIP phone ; )
TrebleTA
Re: FTTP Questions
After something so can have the phone in a different room than the hub with out a ext, ive not look for anything like this before
Re: FTTP Questions
"Apart from a BT Digital Voice handset or an actual VOIP phone ; )"
Indeed. Anything he could connect before FTTP he still can would have been clearer 🙂
Re: FTTP Questions
There are thousands of DECT extenders on the market. Have a look for them.
TrebleTA
Re: FTTP Questions
So I've had a peek, but how do they work?
Re: FTTP Questions
@TrebleTA
Either black magic or fairy dust, I'd imagine.
Seriously, a set of cordless (DECT) phones with however many handsets you need is the answer.  The 'base' unit plugs into the Broadband Hub phone port (on a longer lead if you wish), and the other handsets talk to the base using a particular variety of wireless communication: they use internal batteries and each has a charging stand.
