Discussion topic: FTTP Gigafast ONT size and cable size
This message was authored by reddwarfcrew This message was authored by: reddwarfcrew
Hi, I've orderd gigafast (mainly for the better upload speeds) and want to get everything set up to make the install painless.
Can someone confirm the dimensions of the ONT?
also what size hole will i need to drill for the fibre from the junction box outside into my home.
Thanks.
Sky Q 2TB UHD, 3 Sky Minis, Sky Gigafast SR203.
Re: FTTP Gigafast ONT size and cable size
@reddwarfcrew
The favoured ont is the nokia and the dimensions are below
89 x 82 x 25 mm(Nokia) – 90 x 82 x 25 mm (Huawei)
However the work including bringing in the fibre and drilling will be done by openreach
reddwarfcrew
Thanks that's great, really helpful.. both are basically the same size 🙂
Yep I know the work to bring the cable in will be done by Openreach, I just want to put the hole in place.  It's literally next to where O/R will bring the cable up through the ground as they've already put blue rope up thru the ducts around the estate. Just want to drill the hole in the right place.
@reddwarfcrew
In addition the ont will be placed up to 10metres from where the fibre enters the property and 3ft from the nearest electric power socket and would strongly advise against pre empting openreachs by the book installation
