Discussion topic: Extremely intermittent internet
Message posted on 08 Feb 2026 02:06 PM
My router seems to be going in a cycle, it connects with all three lights lit up green for a couple of mins then the internet light goes off and connection is lost before flashing orange, then solid orange for a couple of minutes and eventually green again, but just for a couple of.minutes....continue cycle ..
It was fine last night and had been doing this since 6am today. I have tried restarted a couple of times.
Message posted on 08 Feb 2026 02:31 PM
Re: Extremely intermittent internet
@Misthair See below and also run a check with your 2nd link!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
then this,
Try running the line test here to see if any faults are found:
