Discussion topic: Extra sky max pod
This message was authored by: kathdave
Extra sky max pod
Can I have 2 sky max pods running of the same router to extend the WiFi signal into my garage?
Re: Extra sky max pod
@kathdave
You can have a maximum of 3 pods if you have Sky Max on your account so you need to get in contact with Sky about this so if you have a landline phone or Sky Mobile one then 150 is the free number to use to contact them on otherwise.
If not then select "No, I still need help" at the bottom on the above link:
