3
This discussion topic has been answered Discussion topic: Extending WiFi from Sky Max router using EE120 Q booster.
This message was authored by: Apars
I am trying to get my EE120 Sky booster to work to extend the WiFi from our Sky Max router. I can get it to connect using either WiFi or ethernet. All 3 lights come on and stay lit, but it doesn't work as an extender. It seems  it broadcasts it's own SSID which we cannot connect to rather than matching WiFi SSID from the router. What am I doing wrong, or is it that th Sky Q booster isn't compatible with Sky Max router?
This message was authored by: cookiemonsteruk Answer
Re: Extending WiFi from Sky Max router using EE120 Q booster.
@Apars
You would need to subscribe to sky max wall to wall wifi to get the sky max pods
@Apars
Avatar for Apars
Can't afford the max subscription. So wanted to get extender to work.
@Aparss
P.S. sky max is not even compatible with sky sr210 broadband hubs.  They were developed by a company called airties thereas sky max pods use the cloud based plume mesh
