Discussion topic: Extend wifi to summerhouse
This message was authored by: Trace2
How do I get a wifi booster for my summerhouse
Re: Extend wifi to summerhouse
@Trace2
The terms of the Broadband Boost and WiFi Max add-ons specifically exclude provision of boosters for separate external buildings.
This message was authored by: Bulls1974
If your out building is on the mains, then their may be a resolution for you.
 use these to extend our Broadband in the house to where the Wi-Fi is poor (used for a punk in the bedroom in my case.
They work better in homes with newer wiring installs. If you get a pair from Amazon then you can return them if you get insufficient benifit
