Discussion topic: Extend WiFi to an outside cabin
Message posted on 04 Aug 2026 11:17 PM
I want to extend wifi from my house to an outside cabin which will be approximately 8-9 meters away from the router
Message posted on 05 Aug 2026 05:39 AM
Re: Extend WiFi to an outside cabin
If the cabin has a power socket you could try a homeplug or if it hasn't run a long ethernet cable.
Message posted on 05 Aug 2026 07:16 AM
@Ger50 the distance is less important than what lies between the hub and your cabin which will include at least one external wall. Sky do not support WiFi outside your home and the advice to run an Ethernet feed is the best solution you can add a cheap WiFi access point if you wish. Homeplugs more properly known as Powerline Networking adapters use the mmains cable to carry the data and can be bought with built-in WiFi access points are a decent second choice but assume the kit you buy will provide around 30% of the speed stated on the box.
