Discussion topic: Ev charger stable connection
This message was authored by: Marleyoo
Hi, I'm hoping some people on here have come across this problem which is:-
my ev charger needs a stable wi fi connection so that octopus can operate it for charging at cheaper rates throughout the day however the WiFi where the box is going the signal is as dead as a dodo even though it's on the outside of the wall just 3 metres away from the router does anyone have any suggestions on how to extend/ boost the signal to where it needs to be, also do boosters/ extenders actually work.?
thanks
Re: Ev charger stable connection
@Marleyoo
Does this EV charger have an Ethernet port so you can directly connect it to the hub ?
Sky will only send you a pod to boost the signal if you have broadband Max on your account.
@caesarome wrote:
@Marleyoo
And strictly speaking the 'Enhanced Wall to Wall WiFi Guarantee' doesn't cover external spaces anyway.
To some extent, yes, but they are still regulated wireless devices and cannot be any more powerful than the router WiFi is.
What they actually do is receive and repeat signal as a relay.
Avatar for Marleyoo
Hi thanks for quick response I've just had a quick look on the hypervolt website and apparently it does have an Ethernet port👍
Avatar for Marleyoo
Thank you for quick reply
