Discussion topic: Ethernet connection issues
This message was authored by: Kanedo
Message posted on 09 Sep 2024 12:54 PM
I work from home and use an Aruba to connect to my company setup. The ethernet connection does not appear to be working. I use a TP link adapter to connect to the router.
Find out more
Message posted on 10 Sep 2024 11:39 AM
Re: Ethernet connection issues
Does it work via direct ethernet without the powerline adapters?
I am NOT a Sky Employee
Message posted on 10 Sep 2024 12:05 PM
Thanks for your response. I managed to get this working. Changed the cables around to make sure none were faulty. Then unplugged everything and switched back on and this appears to have resolved the issue.
