Discussion topic: Ethernet cable router to PC
This message was authored by: KVn123456
What type of ethernet cable do I need to connect the router to my PC?
The cable I have doesn't fit in the router yellow socket.
Re: Ethernet cable router to PC
@KVn123456 Standard cat5e Ethernet cable is sufficient, if you are way up with a potential higher rated cable and it has a full metal shielding on the connector then it may just not plug into the hub port!
