Discussion topic: Ethernet Connections Using Powerline Adapters Fail To Work
Message posted on 03 Sep 2024 07:25 PM
As the title suggests, I've had lots and lots of issues ever since switching to Sky. Pretty much, my PS5 and computer will occasionally work on ethernet for a day, I go sleep and then when switching my computer or PS5 back on, I have too restart the router or powerline adapter because despite saying there is connection, there isn't.
It will work for a few days at times, and sometimes only for a day if that, any suggestions on what to do? I consider myself quite good with computers but in terms of network I lack much knowledge. I've attempted multiple powerline adapters and they work. I was with Virgin around a year ago and I had powerline adapters for years and never once had an issue, when switching to Sky within a day I had issues with ethernet, and it hasn't stopped since. Any suggestions on what to do as this is getting stupid now.
Also, is there any way possible that I can allow my router to issue more speed to a specfic device, in this case the powerline adapter?
Message posted on 04 Sep 2024 09:34 AM
Re: Ethernet Connections Using Powerline Adapters Fail To Work
@JP2407 Which router do you have from the link below.
Message posted on 04 Sep 2024 10:30 AM
Also which broadband type is Sky supplying? There's a known potential issue between Powerline networking and G.fast (Ultrafast 1 over copper) broadband.
Message posted on 04 Sep 2024 12:20 PM
I have the Sky Max Broadband hub, I'm 99% sure it's running full fibre 100.
Cheers
Message posted on 04 Sep 2024 01:55 PM
Its easy to tell, is your hub connected to a telephone socket or white Openreach box with lights on?
Message posted on 04 Sep 2024 01:57 PM
I have the open reach white box with the four LEDs on.
I don't think the Max Hub is compatible with G.fast, which rules out that as an issue.
As far as I know only the SR204 has a G.fast modem.
Message posted on 04 Sep 2024 01:58 PM
Apologies, I meant the Sky Generic Broadband Hub, the black box.
Message posted on 04 Sep 2024 02:03 PM
If you have the black Sky hub then you should have access to router stats, can you please post them.
Message posted on 04 Sep 2024 07:19 PM
Here is the stats.
Message posted on 10 Sep 2024 10:06 AM
The only thing I can see is a small number of collision packets on your LAN which can sometimes indicate a problem.
If you use direct ethernet, not powerline does the problem occur?
Message posted on 10 Sep 2024 07:23 PM
It seems that it remains the same even being plugged directly into the socket. However, it appears that changing the plug to the one next to it has solved the issue. I imagine this is only temporay, but it's working for now.
Is there any way to get rid of collision packets?
