13 Oct 2022 10:17 AM
Sorry, I am a tech novice! I have a number of Wi-Fi black spots. Sky engineer has suggested using a sky booster 4 via an Ethernet between the hub and the booster.
The booster has previously been used via Wi-Fi for booster purposes. How to I get it to use the Ethernet connection rather than Wi-Fi? And how do I know it's connected in this way?
I am told it should produce 500mps in the same way the router does.
thanks all!
13 Oct 2022 10:22 AM
Posted by a Superuser, not a Sky employee. Find out morePower it on, hold the reset button for 30 seconds then connect the ethernet cable to it.
Whoever told you it should produce 500mbps needs to get their marketing talk sorted out. Theres no guarantee it will produce any sort of speed, what you get depends on so many factors.
13 Oct 2022 10:55 AM
Thought it was optimistic but thanks to your assistance, it now works and making a significant difference.
many thanks!
13 Oct 2022 04:47 PM - last edited: 13 Oct 2022 04:47 PM
@RupertCB wrote:Thought it was optimistic but thanks to your assistance, it now works and making a significant difference.
many thanks!
In a world of wireless, cables can still make for a happier world 😆
