Discussion topic: Error code
This message was authored by: Chris19812
Error code
An error code has appeared
error MR102
i have scanned the QR and it's took me to here
Re: Error code
@Chris19812
This is usually seen on a Sky TV set up not broadband. What Sky TV do you have?
Re: Error code
@Chris19812
Are you a Sky Q customer and this error appears on your Sky Q mini, if so try this:
Turn off your mini box at the wall for about 30 seconds, then turn it back on. If that doesn't work, it might not only be the mini box that has lost connection. Try switching both the mini box and the main box off at the wall for another 30 seconds, then turn the main box back on first. Wait for it fully reboot and then turn the mini box back on.
