Discussion topic: Er110 router
This message was authored by: raymond18
Er110 router
I have a er110 router wish to upgrade to stream fttp will it be changed with new contract.
Re: Er110 router
@raymond18You should get a new router with the upgrade of your service. Did you take out Sky broadband Max or just FTTP?
Avatar for raymond18
Level 4 icon
Re: Er110 router
@Highlinder  at the moment I have sky q with fttc, my contract is coming to a end and I am looking at stream, but I wanted to get fttp for the faster speed so it doesn't buffer.
Re: Er110 router
@raymond18  The normal FTTP router if you don't want Sky max is the SR203
Level 4 icon
Re: Er110 router
@Highlinder So when I apply I should be offered sr 203 hope so.
Re: Er110 router
@raymond18 Do you know, if the new FTTP service is available at your property, you can have stream with FTTC just speed is lower.
Level 4 icon
Re: Er110 router
@JimM1 yes I can.
Re: Er110 router
@raymond18 Your new upgrade to fttp, will probably involve the new method of phone service delivered over fibre, so SR203 router is essential to this as the landline is plugged into the rear of the router, and all existing telephone connections become redundant which includes any extensions etc....
And the MAX is not an option if you have any intention of keeping SKY Q for tv.
But if streaming you could have but personally i would wait as there is issues with it at present.
Level 4 icon
Re: Er110 router
@JimM1 Thank you.
