Discussion topic: Engineer has not turned up
Message posted on 29 Feb 2024 01:31 PM
Message posted on 29 Feb 2024 01:34 PM
Re: Engineer has not turned up
Most 'activation' doesn't require attendance at the address: FTTP installation does.
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Message posted on 29 Feb 2024 01:37 PM
@EmmaVEvans if the engineer is from Openreach the network operator this does happen as they have multiple jobs assigned in a timecslot so where one over runs later jobs get lost.
Sky probably wont know whats happened until the Openreach system updates over night. You should be die compensation see Customer Auto-Compensation | Sky Help | Sky.com
