Discussion topic: Ei fi is down
This message was authored by: Ni8
Ei fi is down
The Wi-Fi  light on my hub is not lit. I have been without Wi-Fi for over a week. It came on earlier today and has gone off again
Re: Ei fi is down
@Ni8
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If it’s a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
