Discussion topic: ERR_CONNECTION_TIMED_OUT
This message was authored by RIA1603 This message was authored by: RIA1603
Good Evening All,
Since Thursday i can no longer access my website. It seems to work fine for everyone else, just not for me.
I get the ERR_CONNECTION_TIMED_OUT message.
The website is www.theprintsyndicate.co.uk
It doesn't work on my desktop or mobile phone using wifi, however if i turn the wifi off on my phone it works using 4g/5g data.
I have unplugged the router for over an hour to try and reset but still no luck. I have also tried the reset button and it is still not working.
Does anyone have any idea of what the problem is and how it can be fixed?
Thank you
Re: ERR_CONNECTION_TIMED_OUT
@RIA1603
In the router admin area under maintenance try clicking disconnect then connect for the line this will release your public IP
I am NOT a Sky Employee
