Discussion topic: Dynamic noip ddns
This message was authored by SteveBrocks This message was authored by: SteveBrocks
Dynamic noip ddns
Just moved to Sky broadbanfd from BT. All set up and connected but:
CCTV wont connect to either pc or phone. CCTV is connected to router by ethernet but I cannot logon to cctv software via laptop (tried laptop on wifi and ethernet) triad vis ip address and by the cctv app but no connection. CCTV app ia also on my phone but will not connect (uses noip ddns.) all credentials are connect, ddns has correct ip address for my router.
Hive hub will no longer communicate. it is also connected to sky router via ethernet cable.
Driving me nuts, everything was spot on with the BT Home Hub.
Spoke to Sky but only suggestion is disable Skyshield but makes no difference.
Thanks in anticipation...
Re: Dynamic noip ddns
@SteveBrocks
This usually happens when the CCTV unit has been configured with a static IP, the BT Router & Sky hub use different IP address spaces so your CCTV unit wont be able to communicate now its connected to the Sky hub.
To fix it you need to access the configuration on the unit and either change it to DHCP or change the static IP to one within the Sky hubs range.
I am NOT a Sky Employee
@SteveBrocks
As @jamesn123 identifies, BT Hubs are set to 192.168.1.x by default, while Sky Hubs offer 192.168.0.x
If subnet masks are set to 255.255.255.0, those ranges can't 'see' each other.
SteveBrocks
Thanks,
My CCTV has always 192.168.1.50, I dont recollect ever setting this as I think it was just allocated by the BT hub? All I ever remember doing  was some port forwarding settings and set the DDNS credentials. There seeme to be less options to set up devices on the sky hub.
Dont understand subnet settings, what ought they be?
@SteveBrocks
What IP is your CCTV unit set to now then?
SteveBrocks
Hi,
It has always been 192.168.1.50
i didnt set it so I assume it was managed by the router?
If i typed that into my browser it took me straight onth the cctv admin page...
SteveBrocks
I will look at it agein when I get home. I have always accessed it with my laptop but it wont log on...
@SteveBrocks
And what is your laptop using to attempt to log on to it? If its 192.168.1.50 then that obviously isnt going to work anymore. You'll need to locally access the unit if thats possible or check the Sky Hubs device list for a new IP address it may have got. If all that fails you'll likely need to factory reset the unit.
SteveBrocks
Thank you, I will try to find out if the sky hub has given it a new ip.
Cheers
SteveBrocks
Any ideas why the Hive hub wont connect with the sky hub. There is nothing to set or log onto with the hive hub, its just plug n play...
@SteveBrocks
Sometimes ethernet devices dont play nice with the Sky hub, can you try changing the ethernet cable used, the port its connected to on the hub or the ethernet mode on the hub to fast.
This message was authored by simon194 This message was authored by: simon194
@jamesn123 wrote:
@SteveBrocks
IIRC the standard Hive hub cable is a 4 core one and for some reason they don't play nice with Sky hub. I've always used a fully wired Cat 5 cable with my Hive hub and not had a problem.
_____________________________________________________
SteveBrocks
My phone app connects to the cctv vie noip ddns and port 18004, not an ip address.
Is it possible to check if port 18004 is open on the sky router?
Sorry for asking but I tried sky support but other than ensuring sky shield is disabled only real advice was to try the forum.
I am struggling with sky to resolve what are hopefully teething troubles. Didn't expect this, support from BT was awesome for me.
@simon194 wrote:
@jamesn123 wrote:
@SteveBrocks
Yah anything that comes bundled with a 4 core cable usually has issues with the Sky hub
@SteveBrocks
Port 18004 wont be open on the Sky hub, by default on all ISP routers any inbound ports are closed and you have to open them manually.
