Discussion topic: Dropping connection
Message posted on 04 Sep 2026 08:49 PM
Dropping connection
Our WiFi stopped working last night and after using all the tools on the Sky site it hasn't come back. Have tried resetting my router and hub and has not worked. The diagnostic tests run through Sky are showing no issues or outages in the area.
Message posted on 04 Sep 2026 08:55 PM
Re: Dropping connection
@Icemom
Firstly it’s worth pointing out that Broadband and Wi-Fi are different. Broadband is the internet connection provided by your ISP (Sky), Wi-Fi is the wireless connection between your hub and devices.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 04 Sep 2026 09:23 PM
I've tried all of the tests and links offered on the sky site and nothing has resolved the issue.
Message posted on 05 Sep 2026 04:31 AM
As stated in my post give Sky a call when the lines reopen later.
Call Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband and it's working. The forum doesn't allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka 'the bot') which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
