Discussion topic: Downloading on Sky Q box causing Wi-Fi issues
Message posted on 29 Oct 2024 09:52 AM
When we try to download films is series episodes on our sky Q box, nothing else can use the Wi-Fi as becomes too slow. It has been like this since installed. All health checks come back with no issues.
Message posted on 29 Oct 2024 12:06 PM
Re: Downloading on Sky Q box causing Wi-Fi issues
What package are you on? What speeds are you supposed to get/do get?
Message posted on 29 Oct 2024 12:22 PM
Our broadband package is Sky Broadband Unlimited. Not sure what we should have but we are getting 19.16 Mbps download and 0.81 Mbps upload, according to my Orbi router speed test.
Message posted on 29 Oct 2024 12:48 PM
If you do the line check in the My Sky app it will tell you. Sky Broadband unlimited though suggests your on ADSL which is becoming an old technology. If your downloading something on your Sky Q box its very likely that it will take up all available bandwidth which will make other devices struggle to load anything. Is fibre not available to you?
Message posted on 29 Oct 2024 12:58 PM - last edited: 29 Oct 2024 01:19 PM
As @jamesn123 indicates, 'Broadband Unlimited' (ADSL) is in fact very limited: it's now the oldest form of broadband still in use, and around 98% of UK properties can get something much better.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband type are available.
