Discussion topic: Download speed
This message was authored by: Graham214
Download speed
Am only getting around 100mb download speed , so sky stream box keeps freezing and is unwatchable
Re: Download speed
@Graham214 given the Sky Stream box can never use more than 30Mb/s its not the speed that is the issue but more likely its instability of the WiFi signal. Streaming requires a steady data delivery so where WiFi is affected by interference you will get buffering issues. Rebooting your hub canhelp as that makes it use the least congested WiFi channel which can help at least in the short term.
The better long term solution is to use Ethernet cables but yhst is often difficult. Powerline networking is a good second best. Lastly improvevthe WiFi coverage in your home but yhat can get pricy.
