Discussion topic: Download speed is not truly reflected
This message was authored by: Munkki
Having performed a speed check online with sky it states 49mbps, but I am still here watching a download of between 1-20 Mbps.
My console and hub are in apart. How is this **bleep** service justified.
Re: Download speed is not truly reflected
@Munkki
Could you post your hub stats
@Munkki
Reduced and fluctuating speed over WiFi is entirely plausible: wherever possible it's always preferable to use ethernet cable.
This message was authored by: Toadpoker
Remember downloading files is only as fast as the slowest connection.....just because you have 49MBps speed, if the site you are downloading from is only 20MBps, then you will only be able to download at 20MBps.  Many sites will actually throttle each connection.
Avatar for Munkki
Avatar for Munkki
Ethernet cable oddly had not impact.
Possibly made it worse.
