Discussion topic: Downgrade broadband
Message posted on 30 Jul 2024 06:54 PM
Downgrade broadband
I'm trying to downgrade from ultrafast to a standard broadband but can't seem to get an agent on the phone who is able to help as it's a staff account. I keep being advised I need to find someone from support in the chat / via the chatbot but I'm stuck in a loop and it won't put me through to an agent all "contact us" goes to this forum or back to main telephone line. I have had broadband drop outs since November, 4 sky engineers and 3 openreach visits, all equipment swapped multiple times. I was advised by the openreach engineer to downgrade and am struggling to get it done. Currently WiFi dropping out every evening around 4-6pm until early hours of the morning (green light, no light, green light, amber light). After an openreach engineer visit the issue resolves for a few weeks then goes back to drop outs.
Message posted on 30 Jul 2024 07:01 PM
Re: Downgrade broadband
Is your Ultrafast over FTTP or G.fast?
Once there's an optical circuit to an address, ISPs and telcos can no longer order wholesale copper service.
Message posted on 30 Jul 2024 07:39 PM
Hey @TimmyBGood its G fast. Ah does that mean it's not possible to downgrade?
Message posted on 30 Jul 2024 07:42 PM - last edited: 30 Jul 2024 07:49 PM
G.fast uses the copper phone pair, so it may be possible to move to FTTC (which is technically a downgrade). That might require switching ISP though.
Ideally you'd go to FTTP if that's available.
Message posted on 31 Jul 2024 04:45 PM
Adding router stats. If someone from Sky is able to help me downgrade please
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN Down 0 0 0 0 0 00:00:00 LAN Up 637332 0 0 2703 0 44:35:35 WLAN (2.4 GHz) Up 631010 33961 0 3501 0 44:33:45 WLAN (5 GHz) Up 19637861 18775636 0 0 0 44:33:44
Message posted on 01 Aug 2024 09:43 AM
That's a little odd: G.fast should generate rather more statistics than are appearing there.
Could you post a picture of what the Hub is plugged into?
Message posted on 01 Aug 2024 02:35 PM
@TimmyBGood reuploaded router stats now I've got a connection (will drop again later) and also a pic of the socket
Message posted on 01 Aug 2024 03:00 PM
Ah, OK, definitely G.fast, as it says on the Openreach faceplate.
Message posted on 01 Aug 2024 03:01 PM
And interesting to note that although it's as speedy as Ultrafast 1 over copper can be, the WAN connection dropped out 12 hours ago.
Message posted on 01 Aug 2024 06:33 PM
Thanks for your replies, what does the WAN dropping out suggest? An openreach issue? It's back down again now same problem according to router stats...
