Discussion topic: Dorrbell connection
This message was authored by: Jordon5
Dorrbell connection
I need to connect to a 2.4GHz on my WiFi so that I can connect my doorbell
Re: Dorrbell connection
@Jordon5 As you have not said what you have only doing the latest, tips above will give you the earlier ones!
Change your WiFi settings for Sky Max or Gigafast+ Hub | Sky Help | Sky.com | Sky Help | Sky.com
