Discussion topic: Don't have wifi
This message was authored by: Stavy
Don't have wifi
My internet is not working. The power,WiFi are green. The voice is orange and the internet is not on
Re: Don't have wifi
@Stavy
▪️I AM NOT A SKY EMPLOYEE ▪️
