Discussion topic: Does sky slow broadband at night?
This message was authored by Danno23 This message was authored by: Danno23
Does sky slow broadband in off peak hours without telling their customers?
Currently barely getting 20mbps over WiFi 2metres from hub. Normally 33-39 and line into the hub close to 50. If the puck was in use requiring 15mbps and further away I don't think it would be viable
This message was authored by JPR007 This message was authored by: JPR007
Re: Does sky slow broadband at night?
@Danno23 No Sky do not slow down broadband at night, though you can occasionally lose connection for a few hours due to maintence.
The speeds that are referred to with broadband connections is always in relation to the wired speed, not WiFi. You pay for the line speed to the router.
If you are getting reduced speed over WiFi at night that suggests some sort of interference, or if you have Sky q, your mini boxes are going into standby meaning your wifi signal could be weaker if you have a larger property.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Danno23
Thanks for the reply. Good idea but this was all about the speed to the router. Once noticed over WiFi I always run a sky check for what service I'm receiving into the router
@Danno23
Would need you to post router stats when its normal and when you notice the issue
I am NOT a Sky Employee
