Discussion topic: Dns routing
Message posted on 01 Sep 2026 10:05 PM
Dns routing
Message posted on 02 Sep 2026 11:03 AM
Re: Dns routing
Hi @Rabovey80
Typically Sky cannot facilitate this type of individual request, however if you switch your hub off for an hour it will typically fetch a new public IP which will likely come with a new gateway and DNS servers.
Message posted on 02 Sep 2026 11:24 AM
Re: Dns routing
Hi James,
Thankyou for the reply, I was going to try this, I then realised that from some other page or post, this was not the best idea as I have only been on the service for a week? I think it suggested waiting 14 days to do this? What are your experiences? I just dont want to wait the 14 days and then not be able to cancel if its no better. Thanks for your help in advance.
Message posted on 02 Sep 2026 11:30 AM
Re: Dns routing
That is outdated advice for ADSL/FTTC lines. There is no 'settling in period' or DLM training, as its known for FTTP lines, FTTP is immediately switched on at full speed and if there is an issue it typically just wont work at all. You wont do any harm by switching your hub off.
Message posted on 02 Sep 2026 11:39 AM
Re: Dns routing
Hi James
Once again, thankyou. I will give that a try this evening after work and see how i get on. Much appreciated
