2
This discussion topic has been answered Discussion topic: Disrupted WIfi
This message was authored by: Deborah213
Disrupted WIfi
For 2 consecutive days and sometimes on multiple occcasions, wifi has been disrupted for all devices in our property and especially Sky glass. Is there a problem with our property? It's really not great that this seems to be occurring more frequently especially when wifi is required for connectivity.
Re: Disrupted WIfi
@Deborah213
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
Re: Disrupted WIfi
@Deborah213
Re: Disrupted WIfi
@Deborah213 if you do mean WiFi (ie the connection between the hub and your devices) then it sounds like hhe issue is interference. Common sources are a neighbour's network using thecsame or adajacent channel if you suspect that rdboot your Sky hub so it findscthr least congested channels to use. Alternatively interference can be generated by faulty electrical equipment like a didgy flourescent light, microwave or anything that sparks. Check your own property as the sourcecis normalky local.
