Discussion topic: Display 2.4 GHz and 5 GHz network separately
This message was authored by: Peddler
Hi there, some of my devices can only operate on a 2.4 GHz network.
One example of this is a smart Wi-Fi fused spur switch.
How can I go into my router to display both the 5 GHz & 2.5 GHz bands please.
This is saw that I can specifically ask my device to connect to the 2.4 GHz network only
Thanks & Regards
P
Re: Display 2.4 GHz and 5 GHz network separately
@Peddler
Do you have a white Max Hub or a previous black model?
Band separation and renaming isn't possible on the Max hardware.
