Discussion topic: Disabled WiFi
Message posted on 21 Mar 2025 09:37 AM
Disabled WiFi
Hi there, i have disabled my WiFi connection at the night time and I am trying to connect it now but I can't
Message posted on 21 Mar 2025 09:47 AM
Re: Disabled WiFi
If you've disabled wifi you can only connect to your router via an ethernet cable to re-enable it. Alternatively, restart your router by switching off at the plug for 30 seconds. Thay should turn your wifi back on.
Message posted on 21 Mar 2025 10:01 AM
Re: Disabled WiFi
I done that but it still does not work
Message posted on 21 Mar 2025 10:04 AM
Re: Disabled WiFi
Please explain what you did to disable your wifi. Do you have Sky broadband?
