Discussion topic: Disable MAP-T
This message was authored by: SDJ82
Disable MAP-T
Can I request MAP-T to be disabled please. I cannot connect to my work VPN and they have advised it is related to Sky and MAP-T
Avatar for SDJ82
Re: Disable MAP-T
I have enabled UPnP and disabled Broadband Shield and still have the issue so need this escalating to a superuser please
Re: Disable MAP-T
@SDJ82 before a request can be escalated please explain which application is not working and confirming you have a white Sky hubs.
Avatar for SDJ82
Re: Disable MAP-T
I have a white Sky Max Hub
I cannot access anything requiring access to the VPN, it is not a specific application, it is anything. Network shares, internal web pages etc...
