Discussion topic: Devices not staying connected
Message posted on 06 Sep 2026 04:26 AM
Message posted on 06 Sep 2026 04:30 AM
Can't connect to ring doorbell
Message posted on 06 Sep 2026 06:55 AM
Re: Devices not staying connected
@GarethHarrison video doorbells not connecting are a common issue as they are normally the wrong side of an exteriot wall. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room let alone outside due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
