Discussion topic: Devices including SkyQ keep disconnecting
This message was authored by: YogiK8436
I have had a problem with my sky broadband router and it keeps disconnecting devices and is unable to reconnect. This includes the SKY Q box and the Sky booster 4 I have. Any ideas on how to fix?
Re: Devices including SkyQ keep disconnecting
@YogiK8436
Try running this line test to see if it finds any faults:
Avatar for YogiK8436
Thank you, but that has not helped.
Strange thing is if I setup my phone on WiFi as a hotspot with same credentials as Sky Router, all the non working devices work again, but then when I switch off the hotspot the disconnect.
Looks like the Sky Router is disconnecting certain devices and not allowing them to reconnect.
All you can do now is to call Sky and report this to them.
