Discussion topic: Devices connecting through the hub
Message posted on 30 Jun 2026 10:12 PM
I have the sky hub and 2 WiFi extenders in my house. With the hub I can get max 900mb and through the extenders max 450mb download.
The issues that I face is that the hub is in my living room and seldomly does my devices reconnect with the hub when I am near the hub and is only connected to the hub if I switch off WiFi and then switch it on again.
Does anyone have a solution to this issue or anyone else face this?
Message posted on 01 Jul 2026 06:58 AM
Re: Devices connecting through the hub
@Andy8888 this does get reported quite frequently you cannot directly control which device connects to which WiFi source while some roam some dont. However given 450Mb/s is far higher than the maximum almost all apps can use this should not be an issue in practical use beyond speed testing.
If you are requiring speeds over 450Mb/s to manage very large files you are losing some time but these activities are rarely required on mobile devices.
Message posted on 01 Jul 2026 08:26 AM
Thanks for the reply Crissie. I guess the issue is I have devices wishing to use the higher bandwidth (that I pay for) but not able to utilise it because of the lack of features from the sky router / device not switching to a faster connection. Makes my decision to have full giga connection look a bit foolish.
Message posted on 01 Jul 2026 08:48 AM
@Andy8888 wrote:Thanks for the reply Crissie. I guess the issue is I have devices wishing to use the higher bandwidth (that I pay for) but not able to utilise it because of the lack of features from the sky router / device not switching to a faster connection. Makes my decision to have full giga connection look a bit foolish.
Not foolish but your expectations were perhaps too high. The link below from ISP Review has an excellent 2 page article on just this scenario.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
