Discussion topic: Device won’t reconnect
This message was authored by: JonathanLoveday
Hello,
I have just set up the new cable issues by sky and my device won't connect to the internet
Re: Device won’t reconnect
@JonathanLoveday
Are you saying you have just had Sky fibre installed and that using the supplied cable you have connected your broadband hub to the ONT, if so when is/was your activation date ?
